Parking Brake not working - Taurus Car Club of America : Ford Taurus Forum
Old 01-02-2013, 04:30 PM   #1 (permalink)
04 SABLE's Avatar
Member Number: 6236
Drives: 2005 Mercury Montego Premier
04 SABLE is on a distinguished road
Default Parking Brake not working
I swear, it seems like a never-ending saga of brake problems with this car . I replaced the driver's side rear caliper because it was locking up and causing my pads to burn. Now that I've replaced it everything seems fine. No problems braking and no excessive heat or anything like that. However, the parking brake doesn't do anything now. When I push the pedal down it has almost no resistance. If I put the car in Drive or Reverse the car rolls freely as if the parking brake isn't even on. I hardly ever use the parking brake but I'd like to have it functional. What do I need to do to make it work? Is there something that needs to be adjusted after installing a new caliper?
I can see the wire for the parking brake move and I can see the parking brake "lever" on the calipers move as well, but it's like it's not applying the brake all the way for some reason.
2005 Mercury Montego Premier--Current car
1995 Ford Crown Victoria LX--Current car
1995 Ford Crown Victoria Base--Beater project car
2004 Mercury Sable LS Premium--TOTALED by drunk driver at 89,000 mi.
04 SABLE is offline   Reply With Quote
Old 01-02-2013, 04:31 PM   #2 (permalink)
Breeves002's Avatar
Member Number: 49890
There should be a parking brake adjuster. You need to let the slack out or th cable. Look under the car and see if it is hanging low or loose.
2012 Kia Soul Base AT 1.6GDI
CLICK HERE
Old 01-02-2013, 04:43 PM   #3 (permalink)
04 SABLE's Avatar
Member Number: 6236
I looked under the car and didn't see anything hanging loose. I also compared both rear brake calipers and the parking brake lever(the thing with the big spring) on both of them does move but the one on the passenger's side seems to have less movement than the one on the driver's side; but both do move.
Old 01-02-2013, 06:02 PM   #4 (permalink)
Breeves002's Avatar
So they aren't moving enough. I don't know how, but there is a way to adjust the Parking brake so its tight.
CLICK HERE
Old 01-03-2013, 10:22 AM   #5 (permalink)
ricer333's Avatar
Member Number: 8134
Drives: 2001 Ford Taurus SES 3.0 OHV - Vulcan Engine Royal Blue - Paint Code: LA
ricer333 has a little shameless behaviour in the past
You should see something like what the right side of the picture here has: 1997 Grand Marquis: adjust..parking brake..Mercury Grand Marquis - JustAnswer
It's a rectangular open box sorta thing with a threaded screw and the cable goes into. Follow the cable down through the floorboard and back to the rear tire. I have yet to see a car that doesn't have one of these setups on it.
ricer333 is offline   Reply With Quote
Old 01-03-2013, 11:46 AM   #6 (permalink)
04 SABLE's Avatar
Member Number: 6236
The only place I remember seeing anything like that was close to the wheel on either side. I have to remove the tire in order to get to it. Does that sound right?
Old 01-03-2013, 12:52 PM   #7 (permalink)
Breeves002's Avatar
It should be somewhere along the drivers side where the cable runs. Just look for it. I have no idea where it will be though.
Ill see if I can find it on all data.
CLICK HERE
Old 01-03-2013, 12:57 PM   #8 (permalink)
Breeves002's Avatar
Looks like this is how you release the tension. My guess is the opposite would put tension back in the system?
CLICK HERE
Old 01-06-2013, 02:08 AM   #9 (permalink)
04 SABLE's Avatar
Member Number: 6236
So I did a little more searching and found that the Montego apparently has a "self-adjusting" parking brake which means that there are no places to adjust the parking brake. I wound up just pumping the brake pedal about 50 times and then pumping the parking brake pedal about 50 times as well. I then left the parking brake on overnight which supposedly helps it adjust. All is fine now. The parking brake grabs exactly as it should and the car doesn't roll like it did before.
That makes me happy since I'm about to take a trip up into the mountains with it. Don't need it rolling away!
